wam
Brake Assist Service Required
Salut,,
Ieri mi-a aparut acest mesaj in bord "Brake Assist Service Required". Daca am vazut ca e cu frana, am oprit imediat ce am avut posibilitatea si am inceput sa verific diverse : m-am uitat la placute, am verificat nivelul de lichid, frana de mana, etc. Dupa ce am pornit masina si am plecat mesajul nu a mai aparut o perioada. Can deram aproape de casa a aparut iar, dar fara sa opresc motorul a disparut dupa cateva minute. Aici pe forum nu am gasit nimic in legatura cu acest mesaj, dar pe alete forumuri de afara am gasit ceva cu "brake position sensor". La ce se refera exact ? Care sunt riscurile ? Exista posibilitatea sa raman fara frane ? Nu prea am incredere in comentariile de pe alte forumuri , deci.........mai bine intreb aici unde chiar exista persoane care se pricep.
in aceasta dimineata cand am plecat nu aveam nici un mesaj. Am incercat cu franari bruste, frana de mana un pic ridicata, la semafor am dat pedale pe loc, orice ca sa vad daca mai apre mesajul, dar " NO MESSAGES.
"I had that message and the mechanic where I have the car serviced said my drivers side axle bolt had come loose and that was causing the sensor to throw the message......I might add as well that I was also getting an ABS message. The axle bolt was tightened and the message(s) went away." - La ce se refera mai exact ??? Eu nu am avut ale mesaj inafara de cel specificat in subiect.
"Ok... Dealer eventually gave in after my car autonomously hit the brakes while I was doing 60mph on a busy road... scared the living daylights out of me. I took it straight round the dealers without cancelling the alarm. They held their hands up and admitted it was a real fault. They said it was the brake sensor switch behind the pedal, and replaced it under warranty.
BEWARE!!! This is potentially lethal. " - Unde se gaseste acest senzor ? Cum se poate verifica si cel mai important cam cat costa unul ? Un PART NUMBER ar fi folositor ca sa studiex problema mai bine !!
MULTUMESC
Vecine exista posibilitatea sa te panichezi, dupa care sa te mai panichezi o data .
Este senzorul din stanga de pe pompa de servo frana.
Hai ca m-am panicat. Ce implica ??? Ai cumva un part number, ca m-as orienta de pret la reprezentanta volvo de peste dunare
Edited by wam
Cumva senzorul ala are o tija care se misca inainte si inapoi ? Stiu ca este cam scump !
Vecine prima data se verifica daca este defect, dupa care se inlocuieste.
Am unul bun la un coleg de forum de la GL, el l-a cumparat degeaba .
Poate fi de la mult mai multe nu neaparat de la senzorul respectiv, de pozitie.
bogdane acest mesaj era si la mine .... nu?tu ai zis ca e senzorul de la pedala de frana.De vreo 2 saptamani nu mai apare mesajul fara a aschimb bujia (nu am avut timp , bujia e in torpedou :D)
Mesajul a aparut ultima oara duminica seara. Pina azi nu l-am mai vazut la fata. Bogdan, o sa vorbim la intalnire daca am timp sa ajung
ceau
Stie cineva cat face o oala de servo pt un S80 ,an 2002 cu DSTC, motor 2435 CC, benzina. Cred ca e gata menbrana deoarece fasaie cand las pedala de frana. Daca pisc frana un pic nu mai fasaie. Specific ca frana e moale nu tare.
mersi
Salut, eu stiu ca daca se duce membrana/garnitura, se schimba tulumba ! Nu stiu si nu cunosc daca exista membrana/garnitura separat !
ceau
mersi
