Andu G
Vand subwoofer auto Clarion cu amplificator JL Audio
2 posts in this topic
Salut baieti si fete,
Vand subwoofer auto clarion de 600 w cu amplificator JL audio e2150. Subwoofer-ul este din osb si fibra de sticla, iar exteriorul este captusit cu un material textil anti-alunecare. Stare foarte buna, atat estetic cat si functional.
Specificatii difuzor:
Subwoofer clarion pfw1051
Subwoofer 10” plat, adancime de montare 76 mm, putere maxima muzica 600 wati, 300 wati rms, bobine voce rezistente la caldura de 4 ohmi, design capac opac cu strat de aluminiu din polipropilena electrolitica, design conic compozit din kevlar/hartie, surround pentru zgomot puternic, compozit copolimer, ansamblu motor magnet dublu ferita si strontiu, piesa pol aerisire hiperextinsa, borne duble bloc placate du aur, panza de paianjen din fir de bumbac cu fir lucios integrat, s.e.t. racire ( tehnologie de emisie pânza de paianjen), carcasa din aluminiu turnat particularizata, garnitura de montare cu suruburi ascunse.
* Reproduction system Subwoofer
* Speaker size 25 cm
* Double-stacked powerful strontium magnet
* Seamless parabolic cone structure for dynamic bass response
* Die-cast aluminium frame
* 4-ohm voice coil Single
* Rear-vented pole piece
* Music peak power (W) 600
* Continuous power (W) 300
* Efficiency (dB/W/m) 87
* Fs (Hz) 35
* Qts 0.79
* Vas (Litres) 22.35
Clarion PFW1051
10" Single 4-OHM Voice Coil Shallow Subwoofer
# 00 Watts of Maximum Music Power
# 300 Watts RMS
# Single 4-Ohm Heat Resistant Voice Coils
# Polypropylene Electrolytic Spun Aluminum Coated Dust Cap Design
# Kevlar/Paper Composite Cone Design
# Co-polymer Composite High Excursion Surround
# Dual Strontium Ferrite Magnet Motor Assembly
# Hyper-extended Vented Pole Piece
# Dual Gold Plated Block Terminals
# Linear Poly-cotton Spider with Integrated Tinsel Leads
# S.E.T. (Spider Exhaust Technology) Cooling
# Custom Designed Die Cast Aluminum
# Hidden Screw Mounting Gasket
# Outside Dimension 10 3/8"
# Mounting Depth 3"
Specificatii amplificator:
Producator: JL Audio
Descriere:
Amplificator 2 canale, clasa A/B. Putere nominala 2 x 70W RMS - 4 Ohmi sau 2 x 110W RMS - 2 Ohmi . Crossover integrat, varailbil intre 40 - 200Hz, panta selectabila LP (12 sau 24dB/octava). Iesire preamplificata passtrough. Distorsiuni armonice la puterea nominala: 104dB sub puterea nominala (in gama 20 Hz - 250Hz ). Raspuns in frecventa 10 Hz - 25 kHz (+0, -1dB ). Nivelul de intrare: selctabil de la 200 mV - 8V RMS.
Dimensiuni (Lungime x Latime x Inaltime): 250 mm x 235 mm x 60 mm.
Date tehnice:
Numar de canale 2, Clasa A/B
Putere nominala pe canal 2 x 70W RMS - 4 Ohmi, 2 x 110W RMS - 2 Ohmi
Putere nominala in punte 1x140W RMS - 8 Ohmi, 1 X 220W RMS - 4 ohmi
Raspuns in frecventa 10Hz - 25kHz (+0, -1dB)
Pret 750 lei.
Predare personala in Bucuresti, iar pentru alte localitati pot trimite colet prin Posta Romana sau orice firma de curierat alege cumparatorul, plata fiind suportata de catre acesta.
Contact prin PM, pe mail la adresa andu_gradu@yahoo.com sau la numarul 0744.420.031.
post-1775-0-80429700-1403510582_thumb.jp
post-1775-0-06166500-1403510586_thumb.jp
post-1775-0-07602400-1403510589_thumb.jp
post-1775-0-36104100-1403510592_thumb.jp
post-1775-0-56061700-1403510595_thumb.jp
post-1775-0-68690100-1403510598_thumb.jp
post-1775-0-85435400-1403510601_thumb.jp
post-1775-0-46404200-1403510604_thumb.jp
post-1775-0-43847600-1403510607_thumb.jp
post-1775-0-59108300-1403510610_thumb.jp
post-1775-0-48388600-1403510724_thumb.jp
post-1775-0-90056300-1403510727_thumb.jp
post-1775-0-40377100-1403510731_thumb.jp
post-1775-0-14197600-1403510734_thumb.jp
post-1775-0-45090500-1403510737_thumb.jp
post-1775-0-35541300-1403510740_thumb.jp
post-1775-0-02789500-1403510743_thumb.jp
post-1775-0-87655900-1403510745_thumb.jp
post-1775-0-18087800-1403510749_thumb.jp
post-1775-0-01754400-1403510753_thumb.jp
post-1775-0-94554000-1403510772_thumb.jp
post-1775-0-14900100-1403510777_thumb.jp
post-1775-0-39380100-1403510780_thumb.jp
post-1775-0-12092600-1403510783_thumb.jp
post-1775-0-68713300-1403510786_thumb.jp
Pretul scade la 730 lei!
